George16
Supermaxx
George16's Avatar
09.21.2008, 12:40 AM
Will you have enough space for the screw holes on those emaxx gears? I have a couple of those and was looking at how are you going to mount them.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
09.21.2008, 12:44 AM
I am sure that I can figure something out. They look more promising than the stock lower gear.
SnoopMaxx
SnoopMaxx's Avatar
09.21.2008, 03:35 AM
I am watching this one
Morten SnoopMaxx
Never to old to play
c",)
09.22.2008, 04:26 PM
More progress. Had the machinist turn the output gear down to the correct width, and shorten the adapter and turn it down for the bearing. My measurements were slightly off, but it is going together ok. Need to drill and tap the mounting holes for the output gear and put the diff internals in properly. Then I can do some testing in the erevo with the 1515!!!
