View Poll Results: Status of your MMM v2
Working Normally 57 47.50%
Failed 46 38.33%
Failed violently, potential safety concern 17 14.17%
Voters: 120. You may not vote on this poll
tc3_racer_001
tc3_racer_001's Avatar
09.24.2008, 04:01 AM
hooray - past the 50% mark! that is good news
edit: well for a few hours
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
stum
09.24.2008, 07:09 AM
Almost forgot.. +1 on violent Failures ** I have multiples so I can't post this**
I still have one good working unit, but the other (recently replaced) went up like a roman candle the other day... only about 20minutes of use in a 4s config on my 8ight buggy with a smaller medusa v2 2000kv motor no less, also using mechanical brakes even :P
Last edited by BrianG; 09.24.2008 at 12:45 PM. Reason: Added violent failure to poll...
Just go Play
Just go Play's Avatar
09.25.2008, 12:59 AM
I've got about 5 packs through my v2 with no problems so far.
Revo 3.3 / Neu 1515 1Y / Flightpower 5s1p 5Ah 25c lipo / MMM v2
cwallis
09.25.2008, 11:10 AM
Mine died after 20 minutes
tc3_racer_001
09.25.2008, 06:50 PM
well thats 100 people... interesting. still around 50%.... not good enough for a v2. briang can u start another thread of the same thing for v3's?? it will be great to see thim improvement, hopefully it will be 100 to 1.
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
magicald
09.25.2008, 08:28 PM
Mine smoked this past weekend after one run with 6S thunder power extreme V2 5000mah 25C pack..ran 12 min and LVC came on...recharged my lipo, hooked it up, flipped the switch, ESC toned, then SMOKE!!! Just delivered to CC yesterday.
Electric Dave
09.29.2008, 08:51 AM
Of course, mine has waited until the worst possible moment to fail. After TQ'ing the Monster Truck class at the RC-Monster "Bash" this weekend, and having a really nice big lead in the main...mine just stopped working when landing (correctly) the big triple. I'm pretty sure the case issue is what got me. Ironically, there may actually be video of this failure...anyway I wonder if one of the Mods can change my vote to a "failed".
It held up to 2.8 days of racing. That last ".2" was the most important though...
Rats.
killajb
killajb's Avatar
09.30.2008, 03:06 PM
My stock MMM V2 went poof today. Minor poof, more like a bec failure rather than a violent meltdown. BrianG, can you please change my vote to reflect this?
Last edited by BrianG; 09.30.2008 at 03:09 PM. Reason: Edited poll as requested...
brushlessboy16
brushlessboy16's Avatar
09.30.2008, 03:13 PM
Rats.
could it be the moisture in the air from all the rain, since the fan is swirling it all around in there?
Electric Dave
09.30.2008, 03:21 PM
I did some more diag last night. It turns on and in a few seconds the lights start to fade and dim...then it's off. I'll bet it's classic BEC failure. Besides, if the moist air was the culprit all the other guys running MMMs should have also had failures...
Can't wait for v3!
09.30.2008, 03:55 PM
Dave - Mine died that day to on my buggy - My bec leads broke just before the 2nd heat so I had to revert to the MMM bec.
It survived everything including the long jump and then died coasting around the track. I'm with Jeff on mechanical stress of the fan connector pushing into the brain board. Even with my cutout there is a clear indent on the foam I had in the insert of the cutout (if that makes sense)
e-mike
e-mike's Avatar
09.30.2008, 03:59 PM
i dont know what happen ...some of my post are deleted...anyway my third v2 come in flame deadly(after 5 min).....very scary thing....
D8t on juice!!
DickyT
09.30.2008, 04:05 PM
Mine is at 45 hours and counting! Here's hoping it stays that way.
RBMike
RBMike's Avatar
09.30.2008, 04:36 PM
What is your set up?
DickyT
09.30.2008, 04:40 PM
converted 3.3 revo, rc-m diffs, locked into 2nd wide ratio tranny, 17/36 pinion/spur.
neu 1515 1y, MMM (unmodded), 4s trc 8000 mah lipo and 4s neupower 5000 mah 25c lipo.
The power switch broke on sunday though, just cut it off and twisted the 2 leads together.
