Fast5sRevo88
09.26.2008, 03:01 PM
Originally Posted by cheesecake View Post
i use the zippy lipos there a bit wide but if you shave the tray a bit they fir just fine. i run a 5s setup
I saw your buggy build that u used mike's tray, are u still use it. Thanks for the info, but i will be using the RCPD one which is about the same dimension as mikes, but i don't know if it is as easy to shave down as mike's.
09.26.2008, 03:07 PM
If you want HV, try the Impulse lipos. I have a 3s 3200mah pack and it's lower profile than a 6c pack.
http://www.hobbypeople.net/gallery/182373.asp
I'm assuming you want 8s? Higher?
http://www.hobbypeople.net/gallery/182374.asp
To me, for hight restrictions the Impulse packs have the skinniest cells available.
Fast5sRevo88
09.26.2008, 05:00 PM
Well 8s would be fine if i had somewhere to put it. This is the tray i will be using and have already ordered....
ID:	5501   Click image for larger version
Fast5sRevo88
09.26.2008, 05:01 PM
That is micke_b's RC8
cheesecake
09.27.2008, 02:58 AM
i put mikes tray in my truggy and now im using the rcpd one it sits way out and it needs a bit of shaving to fit the zippy 5000 its a nice tray though i wish the battery was moved over about 5mm
Fast5sRevo88
10.03.2008, 06:19 PM
Well, i got my buggy, now i just have to wait on everything else.
  • This is what i plan on using;
  • Mike's Motor Mount
  • Flightpower 5s 4350mah Lipo
  • RCPD Ultimate Battery Tray
  • Motor ???
  • Mamba Monster
