The member (magman) replied to me and he'll let me ship out his unit so you can get back in action. I'll send it out tomorrow and send you tracking number. Here is a little video showing what I did to secure my caps:
That's great. I'll be dropping the ESC today and will PM you the tracking number. It will go USPS Priority. Thank you very much.
That's what I was trying to do but I chose to just wrap them halfway in order for the heat to dissipate better .
Lesson learned. I'll shrink-wrap them better with the next one and just try to run them with stock settings.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
You can change the settings to your liking, but I reather have the timing set to middle for the Y wound 4 pole motors. You should also see how many AMPs your pulling just to make sure it's not exceeding the 180A burst.
I don't have an Eagletree to check on the amps . But yes, I'll keep the timing on the middle setting this time around.
Revo with OS .18TZ
