alexxbl
10.03.2008, 08:38 AM
Originally Posted by stum View Post
I highly recommend the Tekno v3 setup over ANY other.. you get a custom chassis, the electri-clutch it is a truly amazing setup.. you continue to use the mechanical brakes as well making it even easier on your motor and the ESC... making the system even cooler.
I don't know for electric clutch, but the weight must be too important, and I don't like the battery tray at the end of the chassis whereas all other kits try to keep battery tray at the front.
stum
10.03.2008, 08:44 PM
I've driven it both ways and it doesn't mess w/ cog or weight distribution... at least with 4s 5k lipo's or a pair of 2s 5k packs.. She jumps as good if not better than the nitro's.... I raced mine for a while as nitro so I should know ;P
