MetalMan
MetalMan's Avatar
10.03.2008, 01:45 PM
You will only be doing speed runs, as there is no way to control more than 50mph for bashing with only 2wd. And if you decided to bash at 70mph, your motor would heat up very fast, and your ESC would most likely thermal. The battery would take it better than both the ESC and motor.
Fast5sRevo88
10.03.2008, 01:52 PM
Ok, thanks, i'm just gonna be bashing, so i'll for 50mph then. On 3s at lower speed, i should have ridicalous torque and runtime, right?
MetalMan
MetalMan's Avatar
10.03.2008, 01:58 PM
Even 50mph might be a bit much depending on the terrain .
You'll have ridiculous torque/runtime regardless of speed , as long as it's drivable.
