hexs fine
mdkenley
hexs fine - 10.05.2008, 10:53 PM
drive line and hexs are fine minus the boots.just looking for a way to tell if its the rear diff or the center diff as that is what's making the noise.do rear diffs go out more than center ones?any upgrade to fix this?
10.05.2008, 10:57 PM
Well, the revo center diff is no stronger than a front of rear diff. So it is taking a fair amount of load. You can take the front or rear center driveshaft out and run the truck 2wd. Don't get on it too hard, but you should be able to tell which diff it is.
10.05.2008, 11:06 PM
Well, the revo center diff is no stronger than a front of rear diff...
True, the diffs are basically the same, however, the center diff sees 2.8462 times less strain than the F/R diffs.
I would check the rear first since that is the one that takes the most beating...
To help the diffs last longer, dial in some punch control to help limit the instant torque. You may also want to look into some aluminum diff cups and cases. They won't flex as much which makes the gears keep a consistent mesh. Granted, the Revo diffs are not the strongest design, but it'll help.
