George16
Supermaxx
George16's Avatar
10.09.2008, 08:26 AM
Just use a 5x8x.5mm shim with a 5mm e-clip and you'll be fine. By the way, that is how all the tmaxx and revo clutches are setup from the factory.
Tekno basically just copied the stock nitro setup and adapted it for electric flatform. They didn't do anything wrong. You'll be surprised to see the replacement looking exactly the same with the ine you currently have.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
