e-rev project
10.09.2008, 08:44 PM
cooling agent, its an oil correct? or just spray with water?
anyone know what size bit i need for the jato pin mod, i was able to drill one shaft easily but i gave up on the other shaft(that was hardened), but now i break the pin every other run (on the shaft i did not mod)and forgot the perfect size of bit..... DOH!!!
thank you thank you
