hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
10.10.2008, 01:10 AM
When I was at the track with DickyT, that happened to him. He cut the switch and hot wired it, and was good to go. Mine on the other hand was truly dead. (I knew because it wouldnt link to my laptop)
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
Ryu James
Ryu James's Avatar
10.10.2008, 01:24 AM
how do i cut the switch and hot wire it?
Jammin SCRT10 Neu 1512 1y
hoovhartid
hoovhartid's Avatar
10.10.2008, 01:49 AM
cut the switch off the end of the wires. expose the wires and twist them together. The ESC turns on and off when you plug and unplug the batts at that point.
all a switch does is connect and disconnect the two wires that run to it.
*edit* dont forget to heatshrink any exposed wire
