10.10.2008, 10:01 AM
If the tabs are copper, it is easy. However very few lipos have copper tabs, and even the maxamps copper tab packs only have copper tabs on the pos side (at least the few dozen I have taken apart..
Al tabs doe require special solder and flux, and I have found that some iron tips do not like the flux.
Making 2 3s packs would not be difficult, but you would need addl main wire, and possibly 2 balance taps. Most 6s taps are different than 3s taps. What kind of tap does it come with? When you are splitting the pack the balance tap can be changed to any style. I prefer hyperion, seems to be the easiest to plug in. I hate the kokam tap, and am not that fond of tp style taps either.
