Go Back   RC-Monster Forums > Support Forums > Novak
JThiessen
JThiessen's Avatar
10.10.2008, 11:15 PM
On his we ran through all sorts of different tests to determine which part was causing the issues (radio/transmitter/wiring) etc. Nothing we changed made any differnce. Tried several different batteries and nothing. I reprogrammed the lipo cutoff, and did seem to change the frequency of the cut outs/offs, but didnt completely eliminate it.
I finally stuck my older 4.5 in his truck, and it ran fine (unfortunatley for him, I removed it!!!).
I read about the potential BEC failure effects somewhere on here. I dont think the thread I was reading was necessarily in regards to a Novak system, but I'm not certain.
Come to think of it, we should hear something from them any day now.
erinkirk
10.10.2008, 11:32 PM
nope..not the batteries..tested all sorts with the same results.
and yes..i've been checking out other forums and a lot are having having problems with the hv pro right now.
i still like novak..owned 4 of them (old versions) very reliable system for mt's.
the hv pros are diff though.its just different.
hobbimaster
10.11.2008, 06:55 AM
Have you tried a different RX? IF its a spektrum RX, they use to have all sorts of problems shutting down, until sent in for updating. In any case you may also want to try a stutter stopper, or capacitor plugged into the RX so that if the voltage dips a bit low to the RX it wont shut down.
Personally I wont use anything under 5000Mah 25C in my rig, just to be safe. Since more and more PPL are jumping on Novaks HV we will see more frequent failures. As with anything electronic things will go south from time to time. But the best thing with Novak is that they have the fastest turn around time once something gets sent in.
tedo
Vermont, USA
tedo's Avatar
10.14.2008, 03:55 PM
Try buying the Novak Glitch Buster. The glitch buster is around $10.
I have the 6.5 HV Pro (e revo) with the glitch buster and it has run flawless on 6000 and 8000 lipos for well over 3 months racing hard a couple times a week.
Good luck.
MBX6T: RX8 2000—sick!!!!
Campbell Buggy Rock Racer on 3S
4x4 Pede
1987 (Gen 1) Lunchbox
erinkirk
10.14.2008, 09:48 PM
yessir..i've tried everything..i have the novak glitch buster, also the spektrum voltage protector for the reciever..with the same results. I tried my 2.4 futaba rx tx..still the same. tweaked the radio for throttle control,re programmed the esc again..still the same. i even bought another set of hv pro..still the same results. my friend here ran his e revo also with the hv pro..and suddenly it just stopped..steering is good but no throttle.did everything to revive it with programming etc..nothing.he is sending his back for replacement.
i like my novaks i have 4 of them old hv's..the hv pro's are just different based on my experience.
JThiessen
JThiessen's Avatar
10.14.2008, 10:00 PM
Good luck.
No, this appears to be an issue with the new systems - something Novak needs to address.
