Thread Tools Rating: Thread Rating: 6 votes, 4.33 average. Display Modes
cornolio
cornolio's Avatar
10.17.2008, 11:14 AM
traxxas employee said that "suspension arms are longer"
xray xt8 MMM neu1515 1y
hotbodies ve8 novak HV 6.5
hotbodies cyclone tc
mugen mtx4(nitro)
lst2(conversion ongoing)
  Send a message via Yahoo to cornolio
JThiessen
JThiessen's Avatar
10.17.2008, 11:23 AM
If you are referring to the same info i saw, he was referring to the extended wheel base arms, which are currently an option for the Revo.
I am curious though if the arms are going to be different. The bulkheads have likely changed to fit the new diff, so they must have had to re-engineer that interface also. Maybe these new bulkheads will make it easier to fit the 1/8 diff's in it now....Linc, get ready.....
10.17.2008, 06:57 PM
My thoughts exactly. The new diff looks a bit wider and the diff case must be a bit bigger to fit the diff and the actuator arm in there, which appears to be bearing supported. Those bearing would most likely be the 8mm od bearings, and will take up some space. I will most likely pick up the summit (as long as the price is ok) and see if the lst diff cases will fit in there. That would make it easy, lst diffs are chaep on ebay and the bulks are about 6-8 bucks for a pair for the std revo (IIRC) so the summit ones will not be much different in price...
