E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.20.2008, 10:40 PM
I can not take credit for this pic, only for being smart enough to save it to my computer This is the pic from Neil you where looking for. I just got my NeuEnergy 4900Mah 3s packs and they JUST fit in, take out the sping from the top and the adjustable stop, nothing in the tray except the foam at the front and the battery.
I can't imagine how crazy that setup is going to be Pimp! I just ran mine on 6s and its crazy! MMM/1515 2.5d Tekno Neu/6s NeuEnergy I have it geared 62/22 just over 40MPH, and it's crazy, 20-25MPH wheelies are nothing. I lost a 17mm nut holding my MaximizerBL/Badlands on so I came back in and put the talons back on. It hooks way better on pavement with the talons.
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
10.21.2008, 05:12 AM
I can take credit for the pic! Thats my truck!
The lotus body behind it is for my TC4.
Lookin forward to watchin this linc!
Have you considered using a bigger spur to get the clearence over the shock mount you need?
...Of course, that would mean bigger pinion, etc....
*EDIT*
Maybe run a couple of these with lutechs 10s;
http://www.hobbycity.com/hobbycity/s...Ah_21-35C_4S1P
Similar speed, and you may not need to mess with the shock mount if you get enought clearance with the larger spur.
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.8333333333333332
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 24
Total Voltage: 29.6
Motor KV: 1577
Tire Diameter (inches): 5.9
Tire Ballooning (inches): 0
Motor Current Draw: 80
Motor coil Ω: 0.008
Spur/Pinion Ratio: 2.25 : 1
Total Ratio: 11.74038 : 1
Tire Circumference (inches): 18.54 inches (470.8 mm)
Total Motor Speed: 45669.92 RPM
Vehicle Speed: 68.28 mph (109.68 km/h)
Estimated Adjusted Speed: 62 mph (99 km/h) - 9% loss
Effective KV Value: 1542.9
KT constant: 0.86 oz-in/A
Motor Torque: 0.36 ft-lbs
Final Torque: 4.2 ft-lbs
Final Power: 2368 watts (3.2 HP)
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
