Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
10.21.2008, 09:01 AM
One sec; the *firmware* fixes BEC problems on the V1 and V2? How's that so? I'm not arguing, just a little confused as I thought it was an electronics issue?
If tthat's the case though, then I might just order a new...well, case (pun not intended, honest!).
Pdelcast
Pdelcast's Avatar
10.21.2008, 09:05 AM
Yes -- turns out that the software was allowing very fast changes to battery voltage ("spikes") which could cause BEC damage. The new software monitors the battery voltage thousands of times a second, and prevents the spikes that can damage the BEC (both during acceleration and braking.)
Patrick del Castillo
President, Principle Engineer
BlackedOutREVO
10.21.2008, 09:25 PM
Thats pretty interesting!
So is the V3 going to have bullets for the motor and batt? If not, I need to find me a V2, get the new case, and firmware. I want to be able to have the bullets
Also, with the taller case, will the BL E-Revo mount be able to be used with the old case? Or will it have play? Or?
