10.21.2008, 10:34 PM
Well you got a motor for free from CC and a loaner MMM from me so not all bad - this was always a risk... I've had three MM's die flaming deaths...
A couple of failures rained molten fets onto my Lipos and burnt holes through HS and plastic wrap right up to lipo sheath...
Tough luck never the same... Look on the bright side you now have a 4s lipo which is perfect for a 1Y and you won't have to wait 2 months for a v3.
CRTIM
10.21.2008, 10:47 PM
after reading stuff like this I'm thinking i should just send in my new in box v2 and just get a new v3 and not take a chance of frying any of my other components ....i was gonna try and run it but i'm starting to think otherwise....can i send in a new unused unit or does it have to be a damaged v2 unit ??
ffactory666
10.21.2008, 10:56 PM
I was thinking the same but the turn around will be bad . Do what i am doing , just download the new v3 firmware into your v2 and contact CC to send you out the new v3 case for free .
CRTIM
10.21.2008, 11:10 PM
good idea ,thats what i may do ....
brushlessboy16
brushlessboy16's Avatar
10.22.2008, 06:45 AM
thanks chris. but now i need someone to rebuild my pack- one of my cells has a loose casing with bubles on it...
Originally Posted by MetalMan View Post
CastleLink is the computer software, and 3.12 contains the 1.20 firmware update for the MMM. The Castle Link USB device doesn't get updated.
I ment the castle link program
Ill call today after school. hopefully its not a total loss for me..
