123revo
10.22.2008, 06:22 PM
well i will thoroughly trouble shoot this on weekend coming up before i have the gruelling wait.
it only really started happening when i started paralleling my a123 packs in 5s2p config.
i paralleled my lipos with no issue but they are 11.1v opposed to 18v
i think the voltage gremlin spike is at work here.
now any config of any type of cell will run randomly then conk out, before it would run until almost flat.
bustitup
10.23.2008, 03:46 PM
my v3 shipped today also
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
10.23.2008, 04:18 PM
I had a similar problem with my v2. It would run for a while and would cut out when I would try to make a top speed pass. Sometimes it would cut off completely and coast to a stop, and other times it would stutter on top... almost like the Novak lvc cut off does when your batteries get low. One time when it shut off completely I went to unplug the battery and as soon as I touched the power wires it started going through the initial beeps like I had just turned the switch on. It ended up being a bad connection in the positive 6.5 bullet connector, not the solder joint but the actual connector. I cleaned it up with a small wire brush and tightened the male bullet with a small screwdriver and all has been well since.
Here is a pic of the connector:
