10.23.2008, 08:27 PM
Wow linc...a vid of the speed run is a must!
10.23.2008, 09:26 PM
Man this will be nuts!
10.23.2008, 11:16 PM
Originally Posted by azjc View Post
as long as you don"t try any any backflips from a stopped position I think you will be ok, WOT from a roll
Sounds like a good idea...
I will definately do that!
I think it will be...
Well, I got some work sone on the old nitro revo that I will be using, stripped it almost all the way down in prep for some serious cleaning. I hate to say this, but I did not clean this truck when I got it used, just slapped the tekno kit in and beat the snot out of it...
So it is a bit nasty, at least two owners of crud and grime... All the plastic will get a good soak and scrub, and i will go thru all of the bearings. May take a few days so sit tight!
