MetalMan
MetalMan's Avatar
10.25.2008, 12:24 PM
and as for not having a center diff, 1/10thscale 4wds dont have a center diff and they EASLIY run just as fast on most all tracks as any center diff equiped 1/8thscale buggy can. NOW we obviously wouldnt want the ball diffs and do as someone else already said and have a belt spur made to fit the 1/8th scale diffs all ready out.
i think its an EXCELLENT idea and concept, it just has some obvious things that need simplfied.
One option is to throw a one-way somewhere between the motor and front diff. It wouldn't be as good as a center diff, but close (could install a neat mechanical brake setup on the front and get front/rear braking bias).
BTW, a "belt spur" is called a pulley
rootar
rootar's Avatar
10.26.2008, 09:43 AM
i had a brain fart the other day
and i agree with blackedoutrevo, there are plenty of tough belt cars already made, they only need to beef it up a little to handle the extra weight and strain of 1/8th scale offroad racing and itd be fine. plus just think if your battery is sitting in the perefect middle you dont have to worry about how big of a battery you run so much like we do now for balance, i mean you could run a 6s 5000 battery in the buggy with a 1500-1700 kv motor and we could easily run 30 minute mains with NO stops , also the chassis could be very narrow since everything sits on the center......
plus to help keep dirt out there wouldnt need to be any holes in the bottom of the chassis and the mud guards could wrap all the way around to the diff housing in the rear and use velcro for the body thus helping keep most all of teh dirt out.
lutach
lutach's Avatar
10.26.2008, 10:26 AM
I could make one work. The problem I see with this concept this guy have, is that have made it too complex. The most effective set ups out there are the most simple. I'll start cooking up some drawing and if time allows, I'll make one. Might be a waste of time, but if it works it should look cool.
