I tried the esc connector both ways. One way it will just light up red and the software never finds it. The other way the software finds the controller and reads settings from it but will not write any changes it says that it gets no response from the controller.
That is exactly what mine is doing, and it will no longer arm after the failed attempt either.
I had a similar situation. I successfully updated the firmware on my MMM installed in my buggy. When I went to update the MMM in my truggy, the software would initially see the ESC then while updating it would get the "no response from controller" message. I tried unplugging replugging the USB cable with same results. I then figured maybe the USB Castle link was the problem, since I had three of them I plugged in another one and tried updating the fireware again. Success, it worked. So if you can try a different Castle link USB module.
I just tried another cable. It gave the same error. This monster has never been ran ever. And its dead. I did try to see if it would arm and it would do nothing but supply power to the reciever and seros.
Wow there is no quailty control at castle.
Well this will be a shot in the dark but did you try removing the software from your computer and downloading it again? I had a similar problem with updating my V2 and that was what I did and it worked the second time around.
