10.25.2008, 01:56 PM
Probably a slightly weaker cell. 0.06v is not much different TBH, but would still be nice to get perfect. May check the balance connection you are measuring from. If dirty, it could account for a slight dip...
david lamontagn
10.25.2008, 02:12 PM
OK Brian, but i don't think that's dirt in the connection, because when the pack is connect to the charger by the balancer harness or if i take a multimeter to check it, i obtain the same reading. No matter if i pt the multimeter lead IN the balancer connector or on the tab on the connector
Anyways, i've balance the pack this morning, and now, i'll put it back on the charger and see how it'll be at the end of the charge.
Is the fact to run with an unbalance cell in a pack could cause it to puff????
