Shark413
Shark413's Avatar
10.25.2008, 02:55 PM
I had a similar situation. I successfully updated the firmware on my MMM installed in my buggy. When I went to update the MMM in my truggy, the software would initially see the ESC then while updating it would get the "no response from controller" message. I tried unplugging replugging the USB cable with same results. I then figured maybe the USB Castle link was the problem, since I had three of them I plugged in another one and tried updating the fireware again. Success, it worked. So if you can try a different Castle link USB module.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
LightningTC
Angry 10.25.2008, 03:47 PM
I just tried another cable. It gave the same error. This monster has never been ran ever. And its dead. I did try to see if it would arm and it would do nothing but supply power to the reciever and seros.
Wow there is no quailty control at castle.
Darion
10.25.2008, 04:07 PM
Well this will be a shot in the dark but did you try removing the software from your computer and downloading it again? I had a similar problem with updating my V2 and that was what I did and it worked the second time around.
Hope you get this worked out,
Darion
