Oppressor
10.26.2008, 06:40 PM
Motors dont draw watts, they make them:
Power (watts) = voltage x current (amps).
I would say compare the listed specs of a neu and hacker that have the same kv rating and length to answer that question (on paper at least).
Since a neu has 4 poles vs 2 on the hackers, I would say you could get away with using a smaller neu to do the same amount as work as a larger hacker- due to nearly double the torque being produced. A 1509 should work okay in a buggy, but I'd say look at other peoples setups to see what they like the most...
I know that i am new here but logic tell me that if 4 poles motors were twice as good as two pole motors there would be no two poles motors on the market and even if a four pole motors had really two time the torque potential of a two polers the controllers and motors would burst in flame way before reaching such torque level as most motors are much more limited by heat than by their magnetic strenght. At that level sheer size and efficiency count and an hacker is nearly as efficient i believe.
Manufacturer aren't stupid, while the hacker have two time less pole each of them have two time the repulsion strenght(two time more meterial). It's like comparing kick to punch. Sure you can punch faster but a kick is a kick.
Of course it hold true only for motors of about the same mass.
The real questions, i believe, should be:
1 Will the motor stay cool enough for my need? (Keep in ming that larger motor radiate more heat)
2 Can it be tamed? (Think power over torque as ultimately it's power that decide how fast it move and accelerate)
3 Can it's power be transformed for my need? (High rev motors with low torque can be geared down to raise torque at wheel and low rev motors with high torque can be geared up to turn the wheels faster.)
Theorically it would be possible to need an overly larger motor for it to stay cool but that would be hard to tame. (Think kb45 for a erevo for example).
Even a single brushed 400 can motor could move a gst 7.7(Would probably need a machinist for gears though). It all depend on how fast you want to move your model (power).
If you want to draw less watt you will have to ask for less power which mean making your model move slower. Also accelerating slower and less often would help but it kinda get in the way of such a thing as fun ;) Smaller motor and esc amp limit could help taking less energy accelerating as you would accelerate less often for a given time period.
A big motor could be surprisingly close to a smaller motor in energy consumption as electric motor have a tendency to take more and more energy till they reach it's rpm or burn trying meaning that a model with a neu 1515 or a neu 2230 would take nearly as much energy to sustain the same speed the difference being in the motor weight to lug around, it's rotational inertia and a slight effeciency difference due to one of the motor being closer to it's ideal power curve.
As for what motor will work well i don't know
auto2
10.26.2008, 08:20 PM
hummm, interesting. one thing for sure the neu runs cool. i never checked what gear im running in relation the motor RPM. i do know I can gear it up at least 5 teeth on the pinion and it still runs at most warm and that speed is a good 50 +MPH
BTW running a 808 with MMM and 5s 3700 enerland 16 or 17t pinion for the track
molak
10.26.2008, 11:15 PM
The one that produces the power your need at the higher efficiency..
It´s a complex matter... It depends on how you gear it, the effieciency "curve" of your motor, the efficiency of your ESC and how you drive it.
Batteries are your power source, a limited one, so each time your slipper slips or your wheels spins, you are shortening your run time..
pd: the efficiency curve should be a 3d map rpm, torque and volts.
