1/5 scale opinion
transtalon
1/5 scale opinion - 10.27.2008, 12:57 AM
I have a 1527 1D motor on my extended Lst2 and with a 5S it was a handful to drive but lacking the topend cause my 5S 8k maxamps seems like dying out. But I think you could only run a 6S or (7S tops) as you will go over the recommended 60,000 rpms rating of the motor. But being a road car it should be lighter than a Monster truck with big tires. My truck weights 18 lbs with full gear on it and that motor never even have problem lighting up the 4 tires
on take off.
Ryu James
Ryu James's Avatar
10.27.2008, 03:45 AM
on take off.
this car weighs about 26 lbs. if i throw the 1527 1.5D with two 5 cells it will probably be in the 20-25 lb range.
your setup was good for 43,000 rpm (the 1527 1D is 2300kv) which is a good setup on a single 5 cell. however, from what i understand the lower kv motor will run cooler and be more efficient. by running the 1500 kv only one 5 cell would be 27k rpm, which is too slow for my tastes. if i double that it will be in a more acceptable range of about 54k rpm. so i would still be below the 60k rpm limit.
check this out: http://www.impaktrc.com/product_info...oducts_id=3076
I would love to see your LST2 though. have any pics? how does the 1527 fit?
Jammin SCRT10 Neu 1512 1y
