auto2
10.28.2008, 07:30 PM
use AIR flow to recharge the battery . also install a set of bicycle pedals where the gas and brake belong . or use virbration to charge the batterys. i saw a flashlight you had to shake to build up a charge. the shocks could do that.
coreyfro
10.28.2008, 07:44 PM
If I were going to collect waste energy, it would be from the heat off of the cylinder.
10.28.2008, 09:02 PM
...or use virbration to charge the batterys. i saw a flashlight you had to shake to build up a charge. the shocks could do that.
Enter Bose (yes, the same Bose that does audio): http://auto.howstuffworks.com/car-suspension9.htm
The flashlight you shake is basically a piston-like motor. Instead of the rotor turning, it goes up and down. Either way, it induces a voltage in a coil, just not nearly as well as a rotary motor.
rabosi
10.28.2008, 10:18 PM
Enter Bose (yes, the same Bose that does audio): http://auto.howstuffworks.com/car-suspension9.htm.....
If it works as advertised that will be awesome. nice find.
