George16
Supermaxx
George16's Avatar
10.29.2008, 08:47 AM
Originally Posted by Hardstyle View Post
Mike told me that he could get the 80mm medusa's in month or so. He will add them in his store then..
I got the tranny fixed, was pretty easy.
That white thing is heatshrink (haven't got pic after the heat up) just to secure the pin. Also put some glue in it
Instead of the drill bit, I enlarged the hole and tapped mine to 3mm and used a yoke setscrew. It's stronger than that bit you used and guaranteed to stay in place too using blue loctite .
I forgot to take a picture of it but here's the same concept on my tmaxx/revo tranny.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Hardstyle
Hardstyle's Avatar
10.29.2008, 09:59 AM
I run a 1900kv motor with 6s2p of A123 cells- mucho powerful setup. Bearing in mind Castle say that you can use 6s lipo with the 2200kv motor, 6s of A123 is equal to 5s lipo, so its just about perfect (if you gear down a touch)
2200 x 19.8 is over 40k. That is quite alot. But have to think about it, im not in hurry, they are releasing the combo sometime next month right? Running 2200kv feigao/bk etc. with 6s2p a123, not a chance
Thanks, have to keep that in mind, if mine doesn't hold up
