10.30.2008, 01:23 AM
WOW. That's sweet linc! So it'll be 4WS with the front and rear tires moving opposite? Hey how did that through-diff come out? It looks like you got the mid-bulkhead worked out, too.
The through-diff works fine. And I modded the bulks and they seem to be fine. I would rather have a set of al bulks for ultimate strength. I should have a set in a week that will work.
The 4ws will have the tires moving opposite for a better turning circle.
Thanks! I really like this truck. I think a set of the losi claw tires from the aftershock would be killer on it. But I will test it out with the talons for now. I can lift the left front tire off the grounf about 8 inches and the center and rear tire on the other side stay on the ground, so it should easily climb stairs, which was my hidden goal that inspired the entire project!
