SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
10.31.2008, 06:05 PM
Usually I don't recommend maxamps, but they are the lightest cells for their capacity. If you don't push them that hard, they are fine and make your motor run cooler as well, due to the smaller amp spikes. If you pair a 6s 5000mah maxamps pack with a neu 1512 2Y, you should be able to get 30 minutes of runtime and be faster than the nitros as well.
Area 52 Ranch Raceway
T.R.C.R.
