Softer springs allow better suspension travel for climbing over objects, while harder springs keep you from smacking the ground when landing every jump. I would say springs which are just hard enough to hold the truck at your desired ride height (on level ground, fully loaded) coupled with a higher weight oil (50-80 weight) would give you the best overall performance.
