11.03.2008, 08:26 PM
I believe the different pinion size is to change the gear ratio to compensate for the larger tires
Unsullied_Spy
Unsullied_Spy's Avatar
11.09.2008, 03:04 AM
+1. You could run a Buggy pinion in your diff (IDK if you need to change the diff case or not, never tried it) and it would give you a taller gear ratio but you would have change out the pinion gear to get the ratio right.
