CRTIM
11.05.2008, 03:56 PM
Originally Posted by cheesecake View Post
There the same chassis jammin copied bce's design on it but it depends on if you need the width. the jammin chassis is a little wider compared to the bce. i know the bce chassis would probably last longer because of better quality so its basically up to if you need the little bit of extra chassis space
thanks cheesecake for chiming in ,i was hoping you would sense i seen over at truggyracer that you had run the BCE at one point...yes,the width of the BCE is a concern ..by looking at some of the pics i was wondering if my RCM battery try was gonna fit ,so thanks for that info and your help as always
