11.07.2008, 08:14 PM
Originally Posted by Burnsi View Post
cool, then i will use the esc brake.
and the brake will not coast runtime?
Just remember to use the esc brake you need to run the forward only kit from losi and a tdr single speed hub. Those 2 parts eliminate the weak factory reverse setup and the one way bearing in the 2 speed setup.
