preventing sparking with high voltage
ncalenda
Need for Speed
ncalenda's Avatar
preventing sparking with high voltage - 11.09.2008, 09:40 AM
I found this article on MGM's site:
How to prevent sparking when connecting batteries with higher number of cells
Where do I get a metalized 0.6W, size 0207, 20Ω resistor?
I have never bought one before so have no idea which one would be ideal for this or which one to pick, all Greek to me.
  Send a message via AIM to ncalenda
11.09.2008, 10:07 AM
Don't do this with a MMM it causes them to fail!
George16
Supermaxx
George16's Avatar
11.09.2008, 10:10 AM
I thought Patrick stated in a post not to do this. I remember one of the guys here burning up his MMMs because of the installed resistor.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Gee
A Horse's Ass
Gee's Avatar
11.09.2008, 11:53 AM
Yeah, I noticed BrianG also put it on his web page. To not install them on the mamba's.
http://scriptasylum.com/rc_speed/_nospark.html
ncalenda
Need for Speed
ncalenda's Avatar
11.09.2008, 12:50 PM
This is good to know since I may own the MMM one day. Since I will be using this for my MGM, any idea what resistor I should get?
Gee
A Horse's Ass
Gee's Avatar
11.09.2008, 01:07 PM
I am going to be starting another hobby in electronics this winter. I should know more about them then. You probably don't want to wait that long though. Check out the link I posted above. It has BrianG calculator that figures out what resistor to get.
ncalenda
Need for Speed
ncalenda's Avatar
11.09.2008, 01:30 PM
I have seen that calculator but I just don't know anything about resistors, anyone have a link to one that will work with 6S or less?
11.09.2008, 02:48 PM
Use the calculator to determine what value/rating resistor to use, then visit somewhere like radioshack, or DIGI-KEY.
slimthelineman
slimthelineman's Avatar
11.09.2008, 03:34 PM
the spark is the best part!!!! especially when someone unfamiliar with r/c is standing next to you!
11.09.2008, 03:39 PM
It does not HAVE to be that exact type. The metalized will probably just be a bit smaller for a given wattage than a carbon type. And you aren't worried about high accuracy or noise (as some carbon resistors do with hi-end audio).
So a typical 1W 20Ω resistor from radioshack will be fine. Actually, any value from 10Ω to 50Ω will work, and power values 1w to 2w will be fine. You could even parallel a couple 100Ω 1/2w resistors (very common) and get the 50Ω @ 1w...
ncalenda
Need for Speed
ncalenda's Avatar
11.09.2008, 11:16 PM
good info, I had went to radio shack just to look and did see them there. I will use this info when I go back to buy one. I had no idea they sold them, I was there for another item.
One question, is the spark harmful? When I saw how to get rid of the spark I thought it would be worth it to get rid of it. It just seems as if it could cause damage.
lutach
lutach's Avatar
11.09.2008, 11:43 PM
The spark will damage the plugs. You should see a few of mine that I used with 12S and even tried 60V once with my 40.160.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.09.2008, 11:52 PM
We need solid tungsten bullet connectors....
11.10.2008, 12:07 AM
Yeah, the spark will pit the connectors. Not only does this remove material, but the surrounding area gets sooty and does not conduct as well. Over time and enough arcing, the contact resistance will increase quite a bit - and contact resistance is a bad thing.
Some would argue it's better to just replace the connector every so often instead of using some type of resistor, but I kinda like to make my setups so that they last.
brushlessboy16
brushlessboy16's Avatar
11.10.2008, 12:09 AM
I have a question, what causes the charging resistor for spark control to kill the MMM?
