E-fanatic
Brushless only!
E-fanatic's Avatar
11.10.2008, 05:22 PM
That will do. I have the same one and it come set up at 5volts output. I hooked it up to the castlelink and set it at 6.7volts(to get the most from the radio and servos and thats what a 5 cell reciever pack puts out) The castle link would be a good investment too since you could use it on the mm and the ubec
Dont forget the motor clamp/heatsink IT IS A MUST!!!!!!!!!!!!!!!!!!!!!!!
JThiessen
JThiessen's Avatar
11.10.2008, 05:59 PM
Hey, JDkid - welcome to the forum. Nothing like that JD Green!
You will need a couple 5mm bore 32P (aka .8mod) pinion gears. Mike has them in his store, as do most other major RC retailers.
