11.12.2008, 02:44 PM
Same rules apply when choosing a suitable medusa- they are just like neus, and same size as the feigaos with regards to L can and XL can sizes etc. I would say a 2000kv 60mm medusa was fine for 14 nimh cells, or 4s lipo if you make the leap one day. A 70mm 2000kv version would be even better, but I dont fancy your chances with nimh cells, they will run very hot with a more powerful motor...
11.12.2008, 07:41 PM
They run hot period.
Andrew32
01.10.2009, 05:11 PM
i started with the same setup as yours, but with a 7xl
1) Your Choice of battery PLug
2) Some 4mm or larger bullet connectors
3) RC Monster Motor clamp (XL size)
4) CCBEC
5) CC Castle Link
6) A 25x25 mm fan helps, but select a gear WITHOUT IT!
7) 5mm 32p gear. I would start at 20 and work your way up to about 24 max
Just a heads up, i tried running my NIMH and the batteries fried...had to go lipo...but then again, now im runnig a NEU...you will soon make the switch
