phatmonk
RC carbon junkie
phatmonk's Avatar
11.12.2008, 08:52 PM
Have to agree with BL RVO those motors cant run on 4s and 3s if your lucky.They are also hard on the ESC.I have experienced 1st hand how the less expensive motors can cause the MMMs to run hot even on 3s.I compared mine to my Neu 1515/1.5 on 3s.Nice conversion though.
JesseV
11.12.2008, 09:47 PM
Hmm, i have to disagree. :) Well maybe its because of the fan + extra heatsink, but the motor was 50-60C after driving. And I was driving inside, so the environment temperature was 20C+.
My pinion is 13t and spur 45t or 46t, so its not that heavy i think. I put low timing on ESC and low start power to keep the temps as they are now.
When I ran the motor outside, around 0C, the motor didnt go much over 20C :)
But yeah, compared to more expensive motors, these get much hotter I guess.
EDIT: The quality of these china motors also vary alot. Last 2800kv XL short circuited because some axle balancing epoxy kind of substance came off of the axle/magnet and went between magnet and coil. So some motors might also get hotter than others.
Time for an update
brushlessboy16
brushlessboy16's Avatar
Time for an update - 11.16.2008, 04:42 PM
Hey guys I have gotten alot of stuff done over the past week.
I realized how heavy the rear of my truck was, and wanted to lighten it up in preparation for racing... so I started to take parts off and weigh them.. come to find out that the motor mount that came with the truck was heavy as hell! ~245g. Its made out of some mystery metal, its really heavy, really stiff and not magnetic.
So last night i got to work on a peice of 2x2 aluminum. Its mounted to the chassis with 2 countersunk m4 screws. about an hour later with the aid of a drill press and a dremel this is what I came up with. 44g! dropped 200g on the mount alone!
Secondly I got a spektrum sr3000 from a friend, and bough a module for my M8. got the module installed and modded the case so the antenna fit's in the stock location- it looks pretty trick
here are some other random pics.
Also Got my lipo back from linc, great job
11.16.2008, 05:01 PM
Nice.
Carraig042
11.16.2008, 05:07 PM
I wonder if it is stainless steel? It is not magnetic.
-Brett
brushlessboy16
11.16.2008, 05:10 PM
-Brett
hmm it could be, look on the right side of the mount, that cut took 15 minutes and 2 reciprocating saw blades
rootar
rootar's Avatar
11.16.2008, 06:18 PM
wow 200 grams is like tagging an extra 1/10 motor around.....btw that reciever box is HUGE!
11.16.2008, 06:44 PM
Why do you always take pics in your bathroom?
brushlessboy16
11.16.2008, 08:24 PM
Ya, i just weighed a stock 540 motor... exactly 202g.. the rx box is the only one i had so it will do
Cuz it has the most light in my house
trev3813
Dsm needed
trev3813's Avatar
11.16.2008, 10:46 PM
I think you just like to be close to your toilet
brushlessboy16
11.16.2008, 10:52 PM
cuz everytime i think of Travis Blackmer it makes me wanna puke
trev3813
Dsm needed
trev3813's Avatar
11.16.2008, 11:36 PM
Exactly, Remember, im black like you :)
JesseV
11.17.2008, 07:30 AM
So how much is the total Matrix weight now? :)
Mine is about 3700grams.
brushlessboy16
11.17.2008, 07:44 AM
I dont have an accurate enough scale at the moment, my litte scale only goes up to 2000g
rootar
rootar's Avatar
11.17.2008, 08:31 AM
well tak the front assembly off and weigh it and take the rear and center and weigh it and then weigh your tires and wheels.....................lol
Tags
cen matrix
