you can use mike's battery trays....or if you plan to run zippy's you can ask mike to mill you a custom tray OR use the Losi battery tray BUT it will take some dremeling and delrin or plastic spacers and creative placing to make it fit.....
Thanks I ordered one of Mikes.I have one of Mikes battery trays in my Matrix and its solid.Heres a pic of the SC8 [URL=http://g.imageshack.us/thpix.php][/URL
I'm currently geared 16/46 w/ MMM and a Neu 1515 1/y/f....any higher and the wheel spin is too much..well....depending on your track....but I put a 19T for asphalt speed runs and it FLIES!!!....and (i believe some on here already mentioned it) the tires screech when you turn and it sounds just like the real thing!!!
Sorry to revive the dead... But does anyone know how thick the Lexan is on the SC8 bodies? And if all the bodies, painted or unpainted are the same?
I converted my Slayer to an e-slayvo using the Erevo chassis... And only the SC8 body will fit right. I still don't see how though.... Cuz the SC8 body is like 25" long... Which I think is longer than the Erevo all together.
ERBE: RCM 1/8 Hybrid Diffs, NEU 1515/2.5d/S MMM, 6S, Losi E-XXL CUSTOM, Neu1515 2.5d, MMM, 6s E-SLAYVO PRO ERevo Chassis w/ Pro 3.3 parts, NEU 1512, MMM, 4S.
