The first set you have there won't fit...I tried them, the hex is right, but the mounting hole is to big.
The second set looks do able though.
The first set is v/heavy...almost too heavy for the crt.5
I'd seen those and like the look of the Prolines, but the widest i've seen are only 1.4" wide and stock 2.2 truck wheels are 2.0" wide. Anyone know of a 2.2" dia x 2.0" width beadlock wheel? And, if so can they handle a tire on 3S? I do tape the inside of my tires which helps a lot on keeping them on the rims, and actually makes the car handle better.
