11.19.2008, 01:59 AM
The tranny is ok. It held up to a 9XL on 14 cells forever once I addressed all the weak spots. Noteably the pins that hold the gears to the shaft. There is a sticky by yours truly that explains what pins to use.
Just be aware than if you keep the 2 speed tranny, you'll also need to keep the mechanical brakes (which I assume you are since you'll be designing it to swap back to nitro).
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
11.19.2008, 02:11 AM
great thanks
i'll take a geez at that pin thing, maby try and harden the stock pins for now but thanks a bunch
