MetalMan
MetalMan's Avatar
11.16.2005, 12:26 AM
The Thunder Power will be able to charge up to 10amps and 10 cells in series (Lipo). Otherwise, you could charge at a slower rate (and get a less expensive charger). And yes, 2 packs can be charge in parallel. I would recommend you pick up a balancer to occasionally balance the packs to keep them as a longer lasting investment.
