VintageMA
VintageMA's Avatar
11.21.2008, 02:16 PM
Welcome to the forum.
I've seen vids of what people claim to be rocking 1/5 and 1/6 conversions and they are underpowered piles of dog-pooh compared with yours! That thing is rockin' fast!! Great job!
Would you mind posting some pics under the hood so we can see the setup and layout?
Thanks for sharing
“Everyone has a right to be stupid; some people just abuse the privilege.”
othello
HV basher
11.21.2008, 02:48 PM
Impressive. Great to see an 1:6 converted to brushless with this power level. Would be interesting to see eagletree Graphs of this built. Don't hesitate to post some pictures ;-)
sikeston34m
sikeston34m's Avatar
11.21.2008, 02:58 PM
Yes please! More Info! LOL
I would absolutely LOVE to build a truck like this.
I can only imagine a Chassis that has LOTS of room. Room for things like Batteries. LOL Or at least, Battery compartments that weren't so limited.
I'm hoping these have some bullet proof diffs in them.
We talk about 10S - 12S setups, but with the E maxx or E Revo, I can't imagine where to put the kinda batteries needed to produce the power.
11.21.2008, 06:49 PM
Welcome, and thanks for sharing. There are a couple 1/5 scale builds here (we generally call fg's 1/5, but we knew what you meant by writing 1/6) but there would be more if we saw your build pics. (monkey see, monkey do) So yes, please post them !
Finnster
KillaHurtz
Finnster's Avatar
11.22.2008, 07:38 AM
x2 please
E-VO-Maxx
11.22.2008, 12:25 PM
Thanks to all for your very warm welcome!
It's a pleasure to share pics with you and I'm going to write some details along with the pics.
I'm also interested in data logging and will try to find out what's suitable for this car. Am I right that eagletree is limited to 150 amps? That might be not enough.
The calculated speed should be 60+ mph with the original gear-ratio (16/48) but I took a shorter ratio (14/48) to get more torque as it is still fast enough.
The highest temperatures i got were 140°F at the ESC and 120°F at the engine.
First 4 pics show the belt drive-unit for the 4WD.
ID:	5879   Click image for larger version
ID:	5880   Click image for larger version
11.22.2008, 12:31 PM
That is very, very, very cool. do you have any pics of the setup under that belt guard thingy?
E-VO-Maxx
11.22.2008, 12:35 PM
The next ones show the engine and the motor flange. The small engine is a Lehner 1930 out of my E-Maxx to give you an impression of the engine size. The weight is 2,2 pounds.
The front part of the flange is custom made; the rear part is taken out of a FG EVO 04. With this unit I can use the engine in the Monster as well as in my EVO 04 and it takes less than 30 min. to change the unit.
ID:	5885   Click image for larger version
ID:	5884   Click image for larger version
11.22.2008, 12:44 PM
Beautiful! That motor is huge. I can't even imagine what a 3080 looks like.
E-VO-Maxx
11.22.2008, 12:47 PM
These are the compartments for the Lipos. I cut them out of 3mm cfk-plates. They allow for four different settings in terms of weight and weight allocation.
1. 1P in front, 2. 1P lower and more rear, 3. 2P in front, 4. 2P front and rear.
ID:	5889   Click image for larger version
ID:	5886   Click image for larger version
11.22.2008, 12:50 PM
Have you considered mounting the 1p tray sideways on the chassis rather than straight and diagonal?
E-VO-Maxx
11.22.2008, 12:58 PM
That's how it looks like with lipos. 1P is 2,7 ponds.
The electrics besides the ESC are voltage-controls for 16 cells plus a voltage control and limiter for the receiver-lipo.
BTW: The 3080 has the same diameter but is 40 mm longer, heavier (3,5 ponds) and of course more powerfull if not to say too powerfull for this car.
ID:	5893   Click image for larger version
ID:	5892   Click image for larger version
