11.22.2008, 04:48 PM
100% correct.
Mid range kv + higher voltage and mild gearing will also give good results like Hoov found; the main distinction being that a mid range kv motor works equally well on lower and higher voltage (4-6s lipo), so long as you adjust the gearing accordingly.
