Update!
Update! - 11.22.2008, 06:11 PM
So here is the next incarnation of the 6x6! Now it has an axi 2826/12 760kv outrunner. Using 14/72 gearing and it seems to be about right. I think I will play with the gearing a bit to get it just right. Also check out the 1/4 scale front steering servo, plenty of power there. I also repaced the rear servo with a hitec 5997tg servo for added power. I have the aftershock wheels/tires, but I want to remove the front tires from the wheels and add some weight. Still a blast to play with, easily goes anywhere I want, even thru foot deep grass!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.22.2008, 11:30 PM
Still a blast to play with, easily goes anywhere I want.....
That's the whole point, isn't it??
11.23.2008, 12:13 AM
You got it! I just realized that the taller aftershock tires will up my speed a bit which is good. I found it more capable in 2nd gear, the motor seemed to make a bit more power with the increased load. I guess the gearing was a bit low for it in 1st. The taller tires should cure that, hopefully.
11.24.2008, 06:29 PM
Forgot the pics a few posts back... Sorry!!!
sikeston34m
sikeston34m's Avatar
11.26.2008, 03:53 PM
Isn't the torque of that little motor incredible? So much in such a small package.
I'm sure you could up the gearing some if you want. Even with the additional weight and the additional drivetrain of your creation.
Looks great! Can I drive it? LOL
11.26.2008, 04:51 PM
Is it a problem having the front steering being so much stronger than the rear steering?
11.26.2008, 05:07 PM
You should make it a tow truck, have a servo actuated arm, and put broken trucks on the back section of the frame...
You and shaun should get together and make some money
hey wrecks em' you pick em'
Funny, I like that idea...
I think you should give me your rc's.
Hmm, I wil have to think about that...
If you come down you are more than welcome to drive it!!! I actually plan to run a pair of 3905 chassis and use the new emaxx tranny with the super low 1st gear for crawling, and the std 2nd gear setup for maybe 25mph. The motor definately has plenty of power, no heat to speak of on either the motor or esc.
It does have more power, but it is not that different. When I go to the 3905 chassis I will run 4 identical servos...
11.26.2008, 07:51 PM
I just spent 4 hours making shelves for 50+ cars, I'll pay shipping and I hope you're serious!!!
11.26.2008, 09:18 PM
It has not been 4 hours since my reply... Try again!
brushlessboy16
brushlessboy16's Avatar
11.26.2008, 10:36 PM
I just spent 4 hours making shelves for 50+ cars, I'll pay shipping and I hope you're serious!!! <----- Epic Failure
11.26.2008, 11:07 PM
Funny, huh!! I would like to see a pic of these "shelves"... HAHAHA
