MetalMan
MetalMan's Avatar
11.16.2005, 07:42 PM
If you were to charge both packs on different channels, you would still need one balancer per pack. If you were to charge both packs in parallel, you would still need two balancers. Any 3s cutoff will work with any 3s Lipo battery. Parallel has nothing to do with the number of cells in series. No balancer on the truck, as balancing is only done during charging (or right after a charge).
