7th scale on road project
7th scale on road project - 11.21.2008, 11:23 PM
So I have a lightning street on road car. It has a .26 in it, and with the 2 speed is good for 45mph. It is a fun car, but I hate nitro, and have not run it for at least a year.
So I decided to make a fast on road car. Planned setup is a kb45 8xl on 6s lipo thru a MMM. I have all of the gear to do this, so I only need to make a motor mount and battery trays.
I will retain the 2 speed and mech brakes. So much room on the chassis that it does not cause any issues, and the lack of reverse is not a big deal as I have large parking lots to play in.
Current gearing is 46/42 spurs and 13/17 on the clutch bell. I plan to use 18/25 pinion gears, as I have them. This requires me to swap the 46t spur to a 49t for proper mesh. This poses a problem, as the steel spurs are specific to this car. I have a mgt 8.0 49t steel spur coming, and will have my machinist mod it to fit the 2 speed hub.
I may also have him make me a motor mount. The kb 45 motors have a 30mm spacing and use m4 thread screws, so a rcm mount will not work. I cannot use any adapter, as the motor shaft will not be long enough.
Heres a link to a few pics:
http://www.hotbodiesonline.com/light_street.html
I will get some of the stripped chassis and my proposed layout.
TexasSP
Something, anything, nothing
TexasSP's Avatar
11.22.2008, 10:32 AM
Is it 4wd or 2wd?
DO you have a different body than the advertised one? Kinda fugly in the awkward blue color but the project should be fun.
www.cubicle101.com
11.22.2008, 11:09 AM
4wd, center diff
11.22.2008, 12:58 PM
Sounds good. Why not just have mike make you a motor adapter?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.22.2008, 01:07 PM
Geez Linc, another project??? Looks like a nice one though.
11.22.2008, 01:29 PM
Originally Posted by TexasSP View Post
Is it 4wd or 2wd?
It is basically a HB lightning buggy with a stretched center chassis. I only have the skyline body, but the blue is much nicer in person, less watery looking than in the pic. I may investigate to see if the dm1 bodies have the correct wheelbase...
4wd, center diff
Actually it has a 2 speed, but thanks for playing...
From what I can gather Mike is extremely busy, and I would hate to bother him.
Thanks, I like to have a few (10+) projects going at the same time. I just pick what to work on depending on my mood. For the past few months I have focused on crawlers, before that it was monster trucks. Now I am back to speed, so on road cars will keep me entertained. I have this car, a new gtp, and my 10th scale tamiya tt-01 to fix and modify. Something is going to beat 100mph, and I will have video proof!
11.22.2008, 03:45 PM
"Actually it has a 2 speed, but thanks for playing..."
so its direct drive to both diffs? I knew it was 2 speed, but I've seen center diffs with 2 speeds. My bad!
11.22.2008, 06:08 PM
They just removed the center diff and replaced it with a 2 speed. So the center shaft that the spurs ride on is solidly connected to both diffs. I prefer the solid center for on road, makes drifting more fun/easier!
11.22.2008, 08:45 PM
A 100mph 7th scale...wahoooo!
11.22.2008, 10:00 PM
Sounds like fun huh!
