George16
Supermaxx
George16's Avatar
11.23.2008, 07:07 AM
Can't wait to see the video Jordan.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Tape??
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Tape?? - 11.23.2008, 08:33 AM
With all of that tape in the tires did you balance them??? If not you will be surprized just how much vibration they can let out, which will affect your vehicles performance. Good luck with the initial testing Jordan. Glad to hear that your worked out the kinks on the MGM. I will be doing that soon myself.
jordan...
one.five.two.seven
11.23.2008, 08:39 AM
LOL, i had no idea about balancing them when i did it, but believe me after running up in the air i could see what was happening and how important balancing is, hopefully it doesn't make too much of a difference. Hope you have some good luck with your MGM as well, not to hard when you get everything in the exact right sequence
11.23.2008, 12:01 PM
You did it!!!!!!! I am stoked for the vid!!!!!!
jordan...
one.five.two.seven
11.24.2008, 02:58 AM
Hey guys,
Well, i have got a video for you guys as promised, but i dunno, im a bit dissapointed. The ESC got pretty hot, so i stopped once it reached 170F-180F. The batts were 80F-90F and the motor was 110F. The pinion also came loose the first time i took it out, so that had to be fixed.
As for the truck, it handled awesome, the racerX was worth every penny, it would spin on the spot if i started to fishtail it, but not roll going at full pace. Heres the dissapointing part, it was SLOOWW, as you might be able to tell from the vid. I doubt it was going over 35mph flat out. I'm not too sure why this is though, i am assuming something is wrong with the gearing. But a hot ESC = overgeared, which means it should be too fast right
Also it would not pull wheelies, but keep all four wheels planted when i took off, not to sure if thats the centre diff and setbacks working, or my gearing though.
Anyway heres the vid, dad was filming this one, and my head gets in the way a couple of times :
Any ideas to why it is slow and the ESC is overheating? Also, the motor/ESC connections seem to be pretty weak, sometimes id have to wiggle them around to get the truck to stop cogging, would that affect the speed? I would love to hear your feedback and suggestions
jordan
Funny Vid.
JERRY2KONE
JERRY2KONE's Avatar
Funny Vid. - 11.24.2008, 05:10 AM
Ha Ha Ha I thought this was a Godzilla moive when I saw that big head come into the picture. Just yanking your chain Jordan. Yes any kind of lose connections will create heat issues somewhere. Did you check for heat at the lose connections? It also may depend on your setup of the ESC as well if you have something set too soft or too hard. It looked as if it was running fairly well for the most part. Sometimes gearing the vehicle too low will also give you overheating issues. How about some close up pics of the truck now that it is finished. Nice to see you finally having some fun with all of your hard work.
jordan...
one.five.two.seven
11.24.2008, 05:21 AM
Ask and you shall recieve!!! I took these pics when i just got back from the run. Also, im thinking about asking Mike to CNC me CF or Alu motor mount so i can change between pinions easier.
Thanks for the comments as well Jerry, it was good to finally see it running and not break anything!!
P.S you can see i heatshrinked the piggybacks as well in case one of them decided to blow out, i wouldn't lose the cap, just some extra insurance
