11.23.2008, 06:45 PM
Ok, tried to remove the shrink tubing just now... It did not want to come off. So I now know to test the shrink tubing before use to see if epoxy eats into it and sticks!
So I removed the entire wrap to start again. I will say that it is some tough stuff, does not come off easily. So I think the basic theory is sound, just need to perfect the application technique a bit. I will post some more pics when I try it again.
Maybe.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Maybe. - 11.23.2008, 08:02 PM
Good info Linc. Maybe you need to coat the inside of the shrinkwrap with something to keep it from sticking to the epoxy, hence making it easier to remove after the epoxy has hardened/dried. I am not sure what you can use without affecting the epoxy itself, like WD40, or Pam, or some other kind of releasing agent. The proceedure is kind of interesting to watch from the outside perspective. Thank you for sharing this with us.
brushlessboy16
brushlessboy16's Avatar
11.23.2008, 08:43 PM
I was wondering if that was going to happen..
Why not a later of way paper or something?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.23.2008, 09:15 PM
Even better, use plastic sandwich wrap. It's very thin and also impermeable. Wax paper might still allow some epoxy to get through and stick it all together, plus it's much thicker than the plastic wrap.
