Go Back   RC-Monster Forums > Support Forums > Team Tekin
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
11.25.2008, 03:26 PM
I took a closer look. When that little strip connected the polarities it heated the plastic and caused it to melt around the connectors. They were fused together, but not touching. It was just the plastic that melted.
Shorted for a split second. I saw the spark, immediately pulled them apart, then realized the plastics had melted and hardened. There were two deans connectors. One on the battery and R1Pro. The other was an inline "plug in" style on the BEC. I wanted it like that so I could take off the bec quickly if I wanted to instead of directly soldering it to the + and - of the ESC.
It didn't fuse the + and - together on the battery. It just fused those first two deans connectors together. Does this make any sense? I can take a picture if I need to. Thanks for the help.
:D
jhautz
jhautz's Avatar
11.25.2008, 04:09 PM
Check all of the connections and even resolder them all just to make sure you have good joints. Also do a good inspection of the Capacitors to make sure they werent damaged.
What settings are you using on the R1Pro? Set the start power to low and the timing all the way down to start with. Do you have the Hotwire for the R1Pro? If not, you should get it. It allows you to adjust some stuff that the standard button programing will not.
to make it...
or break it...
Silent...But Deadly
