stum
12.03.2008, 06:46 PM
@stum
Front/Rear balance should not be an issue with this setup (on the contrary) as the motor + 2 servos + receiver + ESC are positioned in the front. Those components will easely counterwheigh both lipos (6s2p 4400mAh). Of course it will depend on the weight of the lipos. This problem would also arise with your setup but would affect your right/left balance.
Keep in mind the battery sits more centered on the chassis, the center diff is offset and it's hard to see from that angle in the photo. The 1515 is way out the other side and has the v3 motor mount and plates for weight (diff and servo's too). The MMM is just off center on the motor side as well evening things out more. The l/r is great as long as I keep it 5s 5000 or less (660grams).
