kulangflow
Never Fast Enough
kulangflow's Avatar
12.05.2008, 08:20 PM
It should just take a second. It's just the flip of a servo.
johnrobholmes
johnrobholmes's Avatar
12.05.2008, 08:56 PM
When the dig engages, it will cut power to which axle you wish. So lets say you engage front dig, which disengages rear power. The rear will totally lock up since it is a worm gear (on the losi), and drag ass behind. This allows you to turn the front and "burn" or dig around. If the rear has any traction it will allow a tighter turn. Here is a perfect video showing normal locked turning vs dig turning. http://www.youtube.com/watch?v=m_cZ_pwTczo On higher traction flat surfaces with even weight distribution you could get tighter turning still.
It only works well on flat or surfaces where the front is up hill. When you are facing downhill you must engage rear dig and lock the front axle. This will make the rear axle fall down the slope if the front has enough traction to stay put.
Then newest, yet to be available item is the unlockable diff. It would allow tight turning without dig as long as all four tires are on the ground. It would be much more predictable until a tire lost traction or lifted from the ground. If I had to choose, I would take dig over unlockable diffs for a comp crawler, mostly because I have been using dual ESC dig in comps for over three years now. I would choose unlockable diffs on a rock racer.
---JRH---
TexasSP
Something, anything, nothing
TexasSP's Avatar
12.06.2008, 12:03 AM
Thanks JRH, I understand the dynamics now. I knew I was missing something in my head when trying to wrap around it.
I really like the idea of the remote locking diffs for the trail scaler I want to build and am now contemplating trying the Venom crawler with the x-trail chassis when it comes out. From what I can see it looks close enough to work with maybe a few minor mods. I saw another guy who put the x-trail in a CR-01 which gave me the idea. Of course I may wait and try the C-frame chassis from the SCX10 when it comes out. I am deep into my tanks now which has my time taken up this month.
www.cubicle101.com
johnrobholmes
12.06.2008, 02:48 AM
There are so many options for piecing it together, it is surely the fun of it.
I would like to use the losi tranny with the venom axles for the ultimate trail rig. Maybe put a three speed divorced tranny into the lower half of the losi and use my 5 channel radio
---JRH---
12.06.2008, 01:45 PM
That would be very cool. Make sure you make a build thread!
Daytona675
02.09.2009, 03:27 PM
Any updates on this. Hows the losi performing?
TexasSP
TexasSP's Avatar
12.06.2008, 10:09 AM
That would be slick! Part of what draws me to trail rigs is that there is really no limits and so many different ways guys do them. The scaleness is obviously the other factor. Crawlers have some variation but most of the comp formulas are very similar in design from what I see.
www.cubicle101.com
kulangflow
Never Fast Enough
kulangflow's Avatar
02.09.2009, 03:42 PM
The Losi hasn't been released yet. They're still working on the worm gears to get them just right.
